Pitstop discrepancies Preflight report vs Inspector
Arthur
Post by Arthur »
I am experiencing (not the first time) an odd Pitstop behaviour, where Inspector is showing different values than those that come from a preflight report.
In particular - it is about image resolution / size.
Below is an extract from the custom Preflight Profile that is run on the file
And here are the results compared to the Inspector Info on the same object.
Why ??
abailescollins
Re: Pitstop discrepancies Preflight report vs Inspector
Post by abailescollins »
Can you please turn on the resolution preflight option to ignore soft masks and see if that makes a difference.
You can send me the offending file as well if you can. andrewb@enfocus.com
abc@imposition.com
Arthur
Post by Arthur »
It did indeed. It is not reported with incorrect resolution anymore. Interesting...
Thank you ABC :)
abailescollins
You can take a look at the file in PitStop Pro and using the mask tools be able see the mask that's got that excess resolution.
abc@imposition.com
