different tekst line in corners
Im working on a flow in pitstop 2019. I need to put tekst lines in every corner of my print. (Topleft 99-5834 ........, TopRight 99-5834 ........, Bottom Left 99-5834..... and Bottom Right 99-5834........,.) Everything starting with the code is changing every time so i need to fill this part. Is there a way with variables that topleft, topright, bottomleft and bottomright stays in possitison and i can ad the different tekst thats needed..
Re: different tekst line in corners
I think you need Switch and Pitstop Server to do this. Then it's easy to setup with varibles.
Tools at hand: Enfocus Switch, Esko Automation Engine, Esko Imaging Engine, Apogee Prepress, HP DFE, Fiery, Caldera, GMG ColorProof, PressSign, Redhat FUSE, Microsoft Azure and Google Cloud Services.
