Conversion CMYK very faded
schmitzdp
Post by schmitzdp » Sun Dec 13, 2020 11:19 am
when I use CMYK conversion (Pitstop action) on a file exported from Indesign (default profile), the colors become very faded.
Below is the starting file, the result and my default Pitstop settings.
Starting file
Result
Pitstop settings and Action conversion CMYK
My PDF file
https://www.schmitz.be/File.pdf
Which preliminary actions in Pitstop are necessary to avoid this color difference ?
Thank you.
Malcolm Mackenzie
Re: Conversion CMYK very faded
Post by Malcolm Mackenzie » Sun Dec 13, 2020 6:52 pm
Hi
Something odd going on there!
Your settings are fine and here they work.
Can you post the converted file please?
If possible try on another computer.
Malcolm
schmitzdp
Post by schmitzdp » Sun Dec 13, 2020 7:45 pm
Hi
Malcolm
Yes, here is the converted file:
https://www.schmitz.be/converted_file.pdf
Do you have an idea how to fix this?
Thank you
Padawan
Post by Padawan » Mon Dec 14, 2020 9:23 am
Your screenshot showed PitStop Server preferences, so are you doing the conversion in PitStop Server instead of PitStop Pro?
Are you by any chance using the PitStop Server configurator in Switch?
If so, then it is necessary to set color management settings in the configurator itself. This is necessary because the configurator doesn't use the general PitStop Server color management preferences.
Malcolm Mackenzie
Post by Malcolm Mackenzie » Mon Dec 14, 2020 9:56 am
Hi
no file in the link for the processed file.
schmitzdp
Post by schmitzdp » Mon Dec 14, 2020 4:23 pm
Exactly!
I hadn't seen that it could be set in the PitStop Server application's preferences, and besides, it didn't use the general preferences.
Thank you very much!
