Hi, I'm trying out the 'Make trace path' feature in Pitstop Pro. I almost get the results I'm looking for, but I want the created path to be cropped/substracted by the trimbox of the PDF.
This is the result im getting:
Here is the test-file: https://cargo.tabergmediagroup.se/cargo ... lB1MdX.zip
Here is the Pitstop Action: https://cargo.tabergmediagroup.se/cargo ... Hk-_FF.zip
Any help would be appriciated!
Best regards, Magnus
Make trace path (and crop by trimbox)
- magnussandstrom
Re: Make trace path (and crop by trimbox)
Hi Magnus
I think the attached does what you want?
You just need to sort out the overprint as I did not do that.
BTW: did you get my emails about the new PDF Review module Beta?
- Make Trace Path - Add 4 mm offset (ignoring white holes) - ABC.eal.zip
- (3.79 KiB) Downloaded 355 times
abc@imposition.com
abc@imposition.com
Can you make this work in Pitstop pro 2019.
ore can you send me the steps in the flow. (bc if i open the flow it will delete serverall items in the flow) and i can not see whith ones
Afraid it won't work in 2019. We added the new functionality in 2020.
abc@imposition.com
abc@imposition.com
ahh ok than i need to get 2020 edition from the boss..
Good plan. Remember as well PitStop 2021 will be out this year, so probably best to include a maintenance contract so you get that included.
abc@imposition.com
abc@imposition.com
- magnussandstrom
Thanks a lot Andrew, your action works exactly as I intended!
I've been on paternity leave for a while that's why I haven't been involved with the PDF Review Beta. But I'm back at work since last week but had some catching up to do. Jan S told me that the PDF Review 2.0 would be released in february so maybe it's to late to do any beta testing by now?
Hi Magnus, or should I say 'Dad'?
You can still jump on the beta if you wish. You should have all the info and there is a hosted server.
There are a few weeks of beta left, and you can run side-by-side with your production system
Jan is all over it, so you have the choice.
Speak soon
Speak soon
abc@imposition.com
abc@imposition.com
