I have an action that remove all my content except one spot color. I have to run the action twice to remove object..why?
what is missing to run only once?
this îs the action and result
Thanks!
action not run all steps
- [3]03-29-2021.jpg (128.89 KiB) Viewed 2925 times
- [1]03-29-2021.jpg (23.47 KiB) Viewed 2928 times
Re: action not run all steps
If you want to remove everything except one spot color it's much easier
Select Spot Color (specify the spot color)
NOT
Remove Selection.
The NOT reverses the selection, so the selection is everything but the spot color.
NOT
Remove Selection.
abc@imposition.com
abc@imposition.com
Thank youIf you want to remove everything except one spot color it's much easier
NOT
Remove Selection.
works with one spot color
but is it possible except 2 spot colors?
