Page Scaling Factor
LasseThid
Page Scaling Factor
Post by LasseThid »
I have received a couple of pdf files for print from a customer, however the customer has applied a Page Scaling Factor of 10 to the pages, so when I look at the page size it says 23282x28032 mm instead of 2328x2803 mm.
If I try to change the Page Scaling Factor to 1 the page size is correct, but the contents are scaled to 10% (see attached screenshot).
Page Scaling Factor changed from 10 to 1.png (73.23 KiB) Viewed 4505 times
How can I fix the pdf files, so they are the correct size?
LasseThid
Re: Page Scaling Factor
Post by LasseThid »
If I run the action list the pdf will look like it does above, but if I save, close and then open the pdf again it is correct. :lol:
Dunno why I didn't try that earlier...
bens
Post by bens »
Sometimes when PitStop Pro changes things in the document, Acrobat doesn't refresh correctly. Sometimes that's Acrobat being stupid, sometimes it's PitStop not telling Acrobat to update.
Glad you found it :).
