drill hole dieline safety margin
hankwheat
Post by hankwheat »
We have actions to put perf lines and drill holes on our proofs. We then visually check pages to confirm text isn't going to get chopped by the drill but can be time consuming on jobs with high page counts. Is there a check that can be setup to warn if text is inside the drill holes?
I can't seem to find an action that will do that.
Thank you
Malcolm Mackenzie
Re: drill hole dieline safety margin
Post by Malcolm Mackenzie »
Hi Hank
It'll depend on how your file is constructed, ideally the drill marks are on a layer called drill**
You then make a new action
Select objects in Layer drill etc as per the grab
Log selection is set to error
Screenshot 2021-07-23 at 16.33.58.png (28.25 KiB) Viewed 4487 times
hankwheat
Post by hankwheat »
Thanks Malcom, I will set this up and try it.
Malcolm Mackenzie
You will probably need to add
Screenshot 2021-07-24 at 13.14.46.png (7.02 KiB) Viewed 4463 times
So that it's only text overlapping that errors.
abailescollins
Post by abailescollins »
Let us know if you manage to do this, we can help if you run into problems.
abc@imposition.com
