Is there a way to search for and then extract and use a string of text from a PDF file to be used within Switch as either metadata or private data (or really anyhow) so that I can rename the PDF file? I want the name of the incoming PDF to be named by the string of text within the PDF.
I can search for the text segment in Pitstop but I couldn't figure out a way to maybe log the variable text selection. It seems simple enough but I am stuck on finding a solution.
--Evan
Extract Text from PDF for Metadata/Private Data Use
GSBSwitch1
abailescollins
Re: Extract Text from PDF for Metadata/Private Data Use
I think we can do this by getting the text you need reported in the XML report so you can access it, and then use it as a variable to rename the file.
Maybe drop me a mail with some examples of what you want to do, and we can experiment.
I seem to remember doing this before with a customer.
abc@imposition.com
abc@imposition.com
GSBSwitch1
Andrew -- I emailed you directly with example file to test.
GSBSwitch1
Curious if there is any other idea in how to accomplish this. I am starting with a CSV file that will trigger a SmartStream Deisgn VDP config which creates a multi page/record PDF. I then split that PDF into individual PDFs per record (every 8 pages of the original PDF). I then need to name that personalized PDF by the string "EMPLID_Lastname_FinAid2021.PDF". All is static except the last name which is all from the original CSV.
The one idea I was trying is to write that string within Indesign SmartStream Designer template into the live area so that I could hopefully search for it and then use it within Switch to rename the PDF name.
Appreciate any ideas.
--Evan
--Evan
Hey Evan,
Did you get a resolution on this? I am trying to do something similar, where I need to use PitStop to read some text in the PDF then get Switch to push it in a specific direction.
Martin
Martin
Martin
- magnussandstrom
There is an option to 'Select text containing' in Pitstop. Then you can log selection as warning.
For routing the file you can use the Pitstop XML-metadata or the orange warning outgoing connection.
You can use a Switch variable if your specific phrase is variable.
Last edited by magnussandstrom on Wed Aug 23, 2023 12:09 pm, edited 1 time in total.
