dot in XML file name
Danp
Post by Danp » Mon Jul 01, 2019 3:52 pm
Hi Everyone,
Just trying to configure a smart preflight workflow with variables from our MIS.
Problem I'm having is that the matching file names of the PDF's sometimes have a "." in the file name if the job has multiple parts i.e cover.01.pdf, text.02.pdf. When I try to set up the variable fields with a file with a "." in the name other than ".xml" at the end it can't read the file. Other than changing everything else in our current workflow can this be configured in any way to work?
Dan
abailescollins
Re: dot in XML file name
Post by abailescollins » Thu Jul 11, 2019 12:14 pm
I can't think of a way to do this in PitStop Server itself.
You would need to do it upfront, or upgrade to PitStop2Switch to enable you to have more control over the XML and the content needed for the variable.
andrewb@enfocus.com
Danp
Post by Danp » Thu Jul 11, 2019 5:07 pm
Thanks Andrew, we have just sorted a way round it using Planet Press to re-name the files before they go through Pitstop server and then re-name them when they come out.
Cheers
Dan
abailescollins
Post by abailescollins » Thu Jul 11, 2019 5:33 pm
Excellent, glad you got round it.
andrewb@enfocus.com
