dot in XML file name
Posted: Mon Jul 01, 2019 3:52 pm
Hi Everyone,
Just trying to configure a smart preflight workflow with variables from our MIS.
Problem I'm having is that the matching file names of the PDF's sometimes have a "." in the file name if the job has multiple parts i.e cover.01.pdf, text.02.pdf. When I try to set up the variable fields with a file with a "." in the name other than ".xml" at the end it can't read the file. Other than changing everything else in our current workflow can this be configured in any way to work?
Dan
Dan
