Add bleed from contour cut line and move die line to another layer.
I understand cut/die/cutcontour and other spots can be found based on exact naming properties. Is there a way to add bleed from a contour cut line and then move the die line to new layer? Our prep time could be cut using only pitstop and acrobat layer properties if this possible. Thank you for any insight. Have a great day, be safe be well.
Re: Add bleed from contour cut line and move die line to another layer.
Adding Bleed around a contour is not possible in PitStop, at least not at the moment.
Moving the dieline to a new layer is though.
andrewb@enfocus.com
andrewb@enfocus.com
