Global Change - Clean Up Trim Area
j.scott
Post by j.scott »
Does anyone know how i can get the Global Change - Clean Up Trim Area Action to remove the white stroke left under the page information on a pdf exported from InDesign.
I have experimented by building a action that that removes everything outside the trim box but ive often found it can drop off parts of the bleed at are required. Clean up trim area works perfectly apart from leaving the white stoke behind. Shown on the attached screenshot.
Any help would be apprciated.
Screen Shot 2018-04-26 at 13.51.12.png (33.44 KiB) Viewed 8043 times
Bakancsok
Re: Global Change - Clean Up Trim Area
Post by Bakancsok »
The white criteria for registration should be given and the object selected.
