Die line, thru-cuts, CutContour, ContourCut Does the list ever stop!!!!
primarycolorinc
Post by primarycolorinc »
When I am creating an action to remove die lines, do I list them with a comma seperating them or do I create multiple actions, one action per name?
Screen Shot 2020-08-07 at 11.41.54 AM.png (173.8 KiB) Viewed 14353 times
abailescollins
Re: Die line, thru-cuts, CutContour, ContourCut Does the list ever stop!!!!
Post by abailescollins »
Right Action List, wrong configuration.
You need to click on 'Select Spot Color by Name' and then scroll down to 'Select Spot Color name from list'
Then you can add a separate spot color name per line.
abc@imposition.com
primarycolorinc
That worked perfectly! Thank you sir. 8-)
primarycolorinc
When creating action lists and altering, is pitstop and switch the same when wanting to add multiple names? For example, the layers section in pitstop.
I am going to create a action to set the trim box to a die line. In the attributes section, can I put die,dieline,cut,cutcontour,contourcut,thru-cut, etc? This will allow the trim box to be set to the die line and then not if there is not a dieline layer. Does this make sense? I apologize if I made this convoluted.
Screen Shot 2020-08-10 at 10.50.43 AM.png (152.05 KiB) Viewed 14304 times
abailescollins
In Action Lists you'll need to add a 'Select' for each and every layer name.
You'll also have to add the appropriate amount of "OR's" to indicate that the action should work if any of the layers are found.
Be aware though you need a different selection, you don't want the layer. you want the objects that relate to that layer.
You need to select the objects to set the Trim Box.
'Select objects in layer by name' is the one you want.
Then 'Change Trim Box'
with 'Resize Page Box to fit Selection' enabled.
abc@imposition.com
Padawan
Post by Padawan »
When you use regular expressions you don't have to use a single select for each layer name, you can all combine them in one select action with a regular expression. The following one will literally match any layername in your list:
(Dieline|thru-cut|cutcontour|contourcut|cut|die|kiss-cut)
Screenshot 2020-08-12 at 08.53.23.png (47.72 KiB) Viewed 14265 times
When we are already using regular expression, we can also build one which matches anything containing cut or die:
(.*cut.*|.*die.*)
