Offset each time text is found
andrew.rosenthal
We are placing thumb tabs on the first page of each section of a book and would like to offset the graphic each time the graphic is pasted on a page. The catch is the order of sections changes from book to book, and there can be anywhere from 3 to 20 sections. We have a way to select the page searching for text "-1",is there a process to count the number of times an action has fired or to offset the paste location with each paste?
Re: Offset each time text is found
Hi!
In Pit stop preferences / Edit, you can change the horizontal and vertical offset of "Paste copied objects" (or something like that, sorry, my Pitstop is in spanish) option.
Try it.
Try it.
abailescollins
Hi Andrew
Which Enfocus products do you have to work with?
abc@imposition.com
abc@imposition.com
