Hello
Is there a way to preflight a pdf and highlight areas where the dot percentage is less than 3% (in any colour)?
I want to achieve something like in attached image - areas in red are suspicious.
I'm aware of the action "Set minimum printing dot to x%, all separations" but I don't want to alter artwork but just preflight it.
highlighting ares with coverage less then x%
- highlight.PNG (31.87 KiB) Viewed 7252 times
Re: highlighting ares with coverage less then x%
I seem to remember we did something like this with the Check Ink Coverage Action.
It has more options than the check in the Preflight Profile, like 'less than', 'more than' etc.
I would suggest having a play with that.
abc@imposition.com
abc@imposition.com
Indeed, it is possible to check the area for coverage less than 3% (for example), but in the report, the whole image area is marked as erroneous, not individual spots. Also, if one ink has 1% coverage and another has 4% it will be reported as 5% coverage, which is not correct. The check needs to work on channel by channel basis.
Is it possible to achieve something like in the previously attached image, not just a report?
looks like we have some work to do on this.
I think it might be possible using restrictions in PitStop 2017 as we improved the ink coverage check there.
If I have any time I will have a play
abc@imposition.com
abc@imposition.com
