I ran the “Center page content” using Pitstop action, but the page is not centered horizontally and moreover the page object moved to the right side of the page margin.
Could anyone please help/guide to resolve this issue.
Please find the source and processed document in the below link.
https://we.tl/HntDTM0rkq
your help would be greatly appreciated!
Thanks!
Center page content issue - Help needed!
Re: Center page content issue - Help needed!
If you look at the page in wireframe you can see a x in the background.
If you change the media box to +2000 on both sides you can see it's massive.
The reason it's happening is PitStop is taking it's positioning from this object, it's actually a PDF form, and as the text is not centred on it, the position is not correct.
it's an iText created file, which IMHO does not create great PDF files.
On the other hand the form is not visible, so it should not effect the position, so I'm going to talk to development.
