Hello!
I created an actionlist, which throws objects with certain colors to new layers. In Acrobat now I have correctly my two new layers, but in an application like Illustrator or Artpro+, the layers I created exists more than once. Is there a solution for this problem?
Thanks so long for your help!
layer problem
layer problem
- Bildschirmfoto 2019-03-19 um 09.09.54.png (5.94 KiB) Viewed 6593 times
- Bildschirmfoto 2019-03-19 um 09.09.14.png (22.03 KiB) Viewed 6593 times
Re: layer problem
The problem is that layers in Acrobat (PDF) are not the same as layers in Illustrator and ArtPro+
The PDF they are not really layers as such, they are called optional content groups and they behave differently.
The only solution I can think of is to merge them to one layer in ArtPro+ or Illustrator, but unfortunately that might change the appearance of your file.
In those applications objects are 'on' a layer, so merging them might change the object order.
In PDF they are only 'assigned' to a layer, so objects can be in different places in the stack, and still be assigned to the same layer.
Also in PDF objects can be assigned to multiple layers.
Sorry to be the bearer of bad news.
Could there be another approach to what you are trying to do?
abc@imposition.com
abc@imposition.com
Re: layer problem
Because I use this actionlist in a workflow in the AutomationEngine, now my solution is to put in an Artpro+ actionlist in the workflow, which merges down the layers with the same name.
