I have multiple pages that have 2 lines of text that need position adjusted. I have action to paste in correct position throughout all pages but I need help with selecting so I can remove it first.
I need to select 2 lines of text so I can delete and replace with same text in correct position. The way I am doing it now is manually deleting in every page. Then I add the graphic in correct position using the action that adds graphic in the correct coordinates. Your help will greatly be appreciated.
action to select 2 lines of text
Re: action to select 2 lines of text
I think a Select within Region combined with a Select Text Segments with an AND is what you need.
This video might be useful, although its about delete and add graphics, the selection principles will be the same.
https://learning.enfocus.com/pluginfile ... 202021.mp4
abc@imposition.com
abc@imposition.com
