Metadata within HTML from switch
Penguin
Post by Penguin »
Can HTML email put a link for where switch moves files based off the Set Hierarchy Path. This is the Metadata that it looks at to place the processed file. [Metadata.Text:Path="/field-list/field[tag= 'Job_Number']/value",Dataset="Submit",Model="XML"]
I'm not sure how to put that into the email so that CSR only has to click link to go to the processed file. Any help would be greatly appreciated.
Thanks,
Re: Metadata within HTML from switch
You can just put in Switch variables like [Metadata.Text:Path="/field-list/field[tag= 'Job_Number']/value",Dataset="Submit",Model="XML"] in the html template files, Switch will replace it with the value behind the variable. This way you can build the path in the html template.
