I updated the portals to 4.0 and now Switch says that my outgoing Program ID is not valid but it matches my incoming portal so I'm confused. Any help would be appreciated.
Thanks,
Portals failing after update to 4.0
Re: Portals failing after update to 4.0
The same thing happens when updating to 5.0.
I have not had time to play around, but my first bet was to recreate the IN / OUT portals from scratch, giving them the same values as you already had.
In our case it is almost a 100, so I reverted back to 3.0 as it was quicker than recreating those.
But I'd check that first.
Please let us know if it worked.
I've noticed since upgrading to version 6.0 (and I think the same was also happening with version 5.0) that some of our callbacks are failing. Switch Portals is occasionally leaving zip files in this location: C:\Users\username\AppData\Roaming\Enfocus\Switch Server\ScriptData\SwitchPortalsEther (Doing a search for .zip in that location shows up zip files which get stuck).
When this happens, we get an error for the portal saying "unpackJob returned false. Could not unpack. Skipping this file. See previous message for further information." The previous message says "Job ticket does not exist, and could not be restored".
I have tried recreating the portal callback with new values, the error goes away, but eventually returns.
Hello there,
After encountering numerous problem with V3, We decided to take a look at the code from Dominick Peluso, and rewrote it.
Finally we took over the maintenance of Portal app, but the appstore is still not up to date for the new repo for the portal support Here is the new link : https://bitbucket.org/sobookhub2/switch-portal.
Here is the statement before our work (V4 to V6), the Outgoing module Had two major "bug" :
Portal V4
We adressed this by two test :
Portal V5
We had a demand from enfocus in order to make it more compliant with older switch version
Portal V6
Solved an issue with the "program ID" field validation wich is fixed since V6
Since the most frequent error we encounteredFor the moment, we did'nt rework the "incoming" element wich is still in the same state since V3.
We'll try to rewrite this for a futur V7 in order to fix the job ticket writting.
Let us now if it answer totally or partially to your problematics and feel free to give us feedback or idea for futur improvement (TrafficLight, outgoing log, bug that we didn't notice...)
- When the Outgoing try to read a "Zip" in the ether path before it was full written
- When the "zip" file did'nt contain any "job ticket"
Portal V4
- Check if the file "has arrived" for a delimited time (no evolution in file size)
If false, throw an alert, and skipp the file until the next test
- Check if the job ticket was present in the zip file
if not throw an error and skipp file until the next test (repeatidly)
Portal V5
Portal V6
Hi Thomas, thanks for your reply.
Even with version 6, Portals is very buggy. We are seeing zip files getting stuck within Portals folders. When this happens, we get the following errors:
This error gets repeated continually until the zip file is manually removed from the portals folder.
The error is also inconsistent and doesn't occur all the time. It happens with different portal callbacks.
We didn't see any of these errors with version 3.
ThomasDeschamps wrote: ↑Mon Nov 04, 2019 10:51 amFinally we took over the maintenance of Portal app
Instead of forking the project entirely, could you make contributions to https://github.com/open-automation/switch-portals ?ThomasDeschamps wrote: ↑Mon Nov 04, 2019 10:51 amthe appstore is still not up to date for the new repo for the portal support Here is the new link : https://bitbucket.org/sobookhub2/switch-portal.
If I've helped you and you'd like to say thanks, consider adding me on LinkedIn and leaving me an endorsement or recommendation. It helps a lot!
Can you Pm me a "zip" file in order to test it?essexmate wrote: ↑Thu Nov 14, 2019 5:49 pmHi Thomas, thanks for your reply.
