Inject User Account in à job
DamienB
Post by DamienB »
I have a user list (AD).
I want to assign the user account to a job without being logged into Switch Web Portal.
Is it possible to assign a job a "user account" so that only the chosen user sees the Job in Switch Web Portal (with the option View my jobs only)?
Re: Inject User Account in à job
You'll need a script (and the scripting module) which sets the username for the job.
The script can use setUserName() in the job class.
From the documentation:
setUserName( username: String )
Sets the short user name associated with the job. If the specified string does not match the name of an existing user in the user database a warning is logged (but the set operation does succeed).
DamienB
Post by DamienB »
OK thanks a lot.
unfortunately, I don't have the scripting module.
would there be another method or is it the only one?
You could add the variable [Connection.UserName] to an Input folders Private Data. But that require one input folder for each user.
DamienB
Post by DamienB »
OK thanks You 👍🏻
DamienB
Post by DamienB »
OK thanks You 👍🏻
