I have a question because I can’t find any information about my problem.
I need to separare part od path included in the XML file and metadata, witch is like for example: 0450-06-2021\karton.pdf. I need only part before \ character 0450-06-2021. Unfortunately when I use funcion Before \, this character is not recognized.
Do You have some idea how I can get only part before backslash?
My XML file is like:
<Positions>
<Position>
<position_id>124519</position_id>
<order_id>25069</order_id>
<client_name/>
<width unit="cm">100.00</width>
<height unit="cm">100.00</height>
<surface_name>BACKLIT FLASH; 1800X2400;</surface_name>
<color_name>brak</color_name>
<printer_machine_name>FABRI</printer_machine_name>
<file_path root_path="\192.168.1.193\DTP2">0450-06-2021\karton.pdf</file_path>
</Position>
</Positions>
Problem with backslash character \
- Zrzut ekranu 2021-08-2 o 16.17.25.png (93.11 KiB) Viewed 6243 times
Re: Problem with backslash character \
Have you tried to escape it, \\
Hi Jan
Unfortunately not working too. I try to use many combination.
- Zrzut ekranu 2021-08-2 o 16.31.29.png (93.54 KiB) Viewed 6240 times
Then try \/
Switch can for paths "normalize" slashes to be working on both platforms.
Any combination not working.
\/ no
\\ no
// no
"\\" no
ect ect
\/ no
\\ no
// no
"\\" no
ect ect
In the search field you can use Regular expressions to pickup parts from your variable value. That way would probably solve the problem.
Maybe that is the solutions but a little complicated.
Thank You Jan. Maybe someone else will have an idea and face such a problem
That is the solution: ^(\d{4}[- ]\d{2}[- ]\d{4})|()$
Of course only for this case.
Another solution: use the StringSplitter app with separator \
The result will be in private data Split.Part1
https://www.enfocus.com/en/appstore/pro ... ngsplitter
