I have 2 Switch servers set up. When printing large PDFs, one server's performance is noticeably slower(for example, 2 minutes for a pdf on server 1 vs 9 minutes on server 2 for the same pdf).
I have tried to make both server setups as identical as possible. Both have the same resources available. I have managed to narrow down the problem to the Adobe PDF converter drivers. I tried to install the same drivers to both Servers, but the difference is still there and there is no way to check if the same driver versions are installed (to my knowledge).
Has anyone else encountered any similar problems? I am aware that saving pdfs is better, but currently we are using printing.
PDF Performance difference between Switch servers
