NodeJS debugging
MTswitch
NodeJS debugging
Post by MTswitch »
i want to know how can i strat debugging a flow in vscode or better to say how can i debug one script flow in vscode
i set debug mode yes and port 9229 and by vscode in launch.json this setting
i active the flow and press F5 for debugging, but occurred this error :
could anyone tell me what should i do or clearly explain how to do it. there is not good information in documation
ThomasDeschamps
Re: NodeJS debugging
Post by ThomasDeschamps »
These message show-up when VsCode didn't get a return from switch.
There is three main cause :
- Switch flow element is not set-up in debug mode
- Switch flow is not running
- You already done a debug and did'nt restart your switch flow between.
But i agree on that, the documentation is a bit unclear for this process
MTswitch
Post by MTswitch »
ThomasDeschamps wrote: Thu Aug 20, 2020 3:10 pm These message show-up when VsCode didn't get a return from switch.
Thank you for your response
i have done everything and still i get the error
Padawan
Post by Padawan »
Is there any error in the messages?
Sunnyland
Post by Sunnyland »
Make sure you have the document/file in the folder proceeding the script befofe you start debugging
Sunnyland
Post by Sunnyland »
Make sure you have the document / file in the folder proceeding the script before starting in debug mode.
and start the debugger in attach.
Sunnyland
Post by Sunnyland »
Sunnyland
Post by Sunnyland »
MTswitch
Post by MTswitch »
Sunnyland wrote: Fri Aug 21, 2020 7:07 am Make sure you have the document / file in the folder proceeding the script before starting in debug mode.
Tnaks for your response, yes that was the reason
one file must be in flow
MTswitch
Post by MTswitch »
i have another problem and I get the error when I stop the flow manually through the task manager
this is an error " the debugging can be enabled for only one script at a time "
i have tried to change port but it didnt work too
anyone knows where is the problem ?
patej
Post by patej »
Yes I've had the same; if the node script itself breaks, i.e. the debugging session is terminated, Switch continues to wait for response and the Switch_Server process has to be terminated manually. After this the error you mentioned appears and the reason seems to be that Switch is still listening to a main.js debugging in some cache (check the path in the log message) ––> only way we've found around it is to do a Restart Switch Server from File menu before reactivating the flow. Luckily we have a develop server so we can do that quite freely when developing scripts, but of course it would be nice to have lighter solution...
MTswitch
Post by MTswitch »
patej wrote: Mon Oct 05, 2020 1:55 pm only way we've found around it is to do a Restart Switch Server from File menu before reactivating the flow. Luckily we have a develop server so we can do that quite freely when developing scripts, but of course it would be nice to have lighter solution...
yes, i do it now but i thought that there is even easier solution for this
