api call with https
foxpalace
api call with https
Post by foxpalace » Sat Jan 16, 2021 10:00 am
whats wrong with this script, when I execute the Script with nodjs on Terminal it works, when I transpile it, the api-call will never run in Switch????
const https = import('https');
async function jobArrived(s: Switch, flowElement: FlowElement, job: Job) {
    let datei = job.getName();
    let zielpfad = await flowElement.getPropertyStringValue("ZielPfad");
    var splittArray = datei.split("_");
    var jahrArray = splittArray[3].split(".");
    var jahr = 20 + jahrArray[0];
    var suffix = jahrArray[1];
    var objekt = splittArray[0];
    var kw = splittArray[2];
    await job.log(LogLevel.Info, "Jahr: " + jahr);
    await job.log(LogLevel.Info, "Suffix: " + suffix);
    await job.log(LogLevel.Info, "Objekt: " + objekt);
    await job.log(LogLevel.Info, "KW: " + kw);
    await job.log(LogLevel.Info, "ZielPfad: " + zielpfad);
    var url = 'https://url.com/api/v1/titles/' + objekt;
    await job.log(LogLevel.Info, "URL: " + url);
    (await https).get(url, (res) => {
        let body = "";
        res.on('data', (chunk) => {
            body += chunk;
        res.on("end", () => {
            try {
                let json = JSON.parse(body);
                var verladsid = json.pub_publisher_id;
            } catch (error) {
                job.log(LogLevel.Info, "BLA");
    }).on("error", (error) => {
When I try
https.get ... whitout await Visual Studio marks it as error
Regards Michael
Re: api call with https
Post by freddyp » Mon Jan 18, 2021 9:02 am
Same remark as for this post (viewtopic.php?f=26&t=3849): use Promises!
A word of advice for working with HTTP calls: use the axios package. It is easy to use and highly configurable.
const axios = require("axios"); //JavaScript
import axios from "axios";  //TypeScript
    try {
      let result = await axios({method:"get", url:"https://url.com/api/v1/titles/" + objekt});
      //do something with the result
    } catch(error) {
      //do something with the error
For more options and examples, see the axios documentation. When using the examples you find, always make sure not to use the .then callback functions. Remove them and await the axios call. It is as simple as that.
foxpalace
Post by foxpalace » Mon Jan 18, 2021 12:52 pm
Hi Freddy,
you made my day :)
I have to learn, to learn, to learn ...
Greetings Michael
