Text to XML using Node.js in Switch Scripter
Posted: Mon Jan 18, 2021 10:58 am
by mrkkrai
Hi:
Please help me to convert text file to xml using Switch Scripter:
Job1.txt input:
500 LABEL
500
1 1.72 500
1 1.72
21 01 04 HARDING'S SERVICES
Shipped Via :
Purolator Edmonton
Tracking # :
607431612227
PO # : 9197
L 1612296
Job1.xml output:
<tags>
<ShippedVia>Purolator Edmonton</ShippedVia>
<TrackingID>607431612227</TrackingID>
<PO>PO # : 9197</PO>
</tags>
Re: Text to XML using Node.js in Switch Scripter
Posted: Tue Jan 19, 2021 1:54 pm
by foxpalace
has your inputfile always the same structure?
Posted: Tue Jan 19, 2021 2:23 pm
by foxpalace
I need in short a similar Script and I have to learn more TypeScript. So I think this is rudimentary, but it did what you need
import fs from "fs";
async function jobArrived(s: Switch, flowElement: FlowElement, job: Job) {
let dateiname = await job.getName();
let dateipfad = await job.get(AccessLevel.ReadOnly);
let tempfile = "/tmp/tmp.xml"; // you can read the inputfile and put it here
// read the file
try {
var array = fs.readFileSync(dateipfad, { encoding: "utf8" }).toString().split("\n");
} catch(error) {
await job.log(LogLevel.Error, "We could'nt read the File " + dateiname);
// we know how much ARRAYs are here, because the Textfile has always the same lines
fs.writeFileSync(tempfile, '<tags>\n');
fs.appendFileSync(tempfile, '<ShippedVia>' + array[6] + '</ShippedVia>\n')
fs.appendFileSync(tempfile, '<TrackingID>' + array[8] + '</TrackingID>\n')
fs.appendFileSync(tempfile, '<PO>' + array[9] + '</PO>\n')
fs.appendFileSync(tempfile, '</tags>')
// we don't need the old txt-file
await job.sendToNull();
// we create an other job
const xmljob = await job.createChild(tempfile);
//send to outfolder
await xmljob.sendToSingle();
// delete tmpfile
fs.unlinkSync(tempfile);
Posted: Sat Jan 23, 2021 7:50 am
by mrkkrai
Hi:
Yes. The input file has always the same structure. I tried the script in SwitchScripter but it returns error. Please see the screenshot.
https://ibb.co/zhRwnkw
Posted: Mon Jan 25, 2021 2:15 pm
by foxpalace
yes, because you use legacy Script and not TypeScript.
Greetings
Michael
Posted: Wed Sep 15, 2021 7:10 am
by kramer5789
We have built custom solutions for customers that do similar operations.
If you would be interested in having some help, send me a private message.
Looking forward to hearing from you.
Ryan
