I wonder if we're doing it the right way.
we're coding in typescript (main.ts), after any change we run npm run compile (in order to create the main.js).
part of package.json:
"scripts": {
"test": "echo \"Error: no test specified\" && exit 1",
"pack": "SwitchScriptTool --transpile . && SwitchScriptTool --pack . ..",
"compile": "SwitchScriptTool --transpile ."
ist here an easier way?
When will Switch check the modification?
thx in advance,
Ralf.
Typescript / compile
Re: Typescript / compile
Hi Ralf,
Just type "SwitchScriptTool --transpile ." in the Visual Studio Code terminal.
No need to reload the script or restart the flow, the effect is immediate.
If you want to automatically run the command on save, then I think you should be able to use this vs code extension
https://marketplace.visualstudio.com/it ... .RunOnSave
I haven't tested it myself, so I can't help with the configuration.
Padawan,
thx! RunOnSave seems promising. I'll give it a try.
Ralf.
Ralf.
