First impression
Share best practices about BoardingPass during the public pre-release period.
pietdepauw
Site Admin
First impression
Post by pietdepauw » Thu Jul 23, 2020 4:09 pm
Well... if you're here you probably tried it.
What do you think? We're very curious ;)
RytisT
Re: First impression
Post by RytisT » Fri Jul 24, 2020 10:41 am
Definitely something we'd like to use, however this tool could really use integration with PitStop, so we could make our own custom checks. Perhaps such integration is planed?
Rob_Wh
Post by Rob_Wh » Fri Jul 24, 2020 9:37 pm
Just installed and even though I intentionally "messed with" the PDF imported, it's not flagged any of the issues I created.
I rotated a few pages 90 degrees, and removed the bleed on others, but the left pane only shows Seps and Trim size - no warnings like the demo presentation showed. Is this a really REALLY stripped down release? Was hoping to have some Admins give it a test drive, but if it's just a glorified PDF Viewer, I'll wait.
abailescollins
Post by abailescollins » Mon Jul 27, 2020 1:59 pm
You should be seeing warnings and errors for image resolution, missing fonts and missing bleed on the left hand Panel Rob?
You can ping me your test file if you want, you have my email I think.
andrewb@enfocus.com
Rob_Wh
Post by Rob_Wh » Wed Jul 29, 2020 7:03 pm
Andrew,
Ok, I maybe should have tested a few more files! I did a sample PDF out of InDesign with the same intentional errors and boarding Pass did indeed flag them & display in the left pane. However, I rotated one of the pages 90 degrees and it's still displaying ALL the pages as right reading, no warning about a bad rotation in the PDF.
Here's the Sample PDF I created.
john.dean@esko.com
Post by john.dean@esko.com » Wed Jul 29, 2020 8:53 pm
Rob_Wh:
PitStop sees the rotation as 270 degrees. This has given me fits in the past when trying to impose. Certain software honors that rotation, others do not. So, I ran the action, "Zero Rotation Key" and checked the file again with BoardingPass.
Last edited by john.dean@esko.com on Mon Sep 14, 2020 4:56 pm, edited 2 times in total.
<current>Enfocus Marketing Content</current>
<previous>Technology Manager</previous>
<beforeThat>Workflow Architect</beforeThat>
abailescollins
Post by abailescollins » Thu Jul 30, 2020 10:48 pm
Yep, it's the Rotate Key. Thanks Rob, added it to the list for development!!
andrewb@enfocus.com
Rob_Wh
Post by Rob_Wh » Fri Jul 31, 2020 7:45 pm
No problem! Can't tell you how many times the "Zero Rotation Key" has gotten me in trouble. :P
