Converting all colors to process while preserving certain spot colors.
stome
Post by stome »
We do a lot of packaging jobs that contain dielines, perfs, and score lines. Our customers provide pdfs that contain these overprinting spot color elements for reference. Is there an action that can convert all colors to process but bypass or preserve these certain spots colors?
abailescollins
Re: Converting all colors to process while preserving certain spot colors.
Post by abailescollins »
You can make an Action List that does that quite easily.
Do you have a list of Spot Color names that you want to preserve?
abc@imposition.com
stome
Post by stome »
Thank you for your reply. Yes, we do have certain spot color names we as our clients to use in their files. These names include "Dieline", "Perf", and "Score".
abailescollins
Give this a try. There's a list of spot colors that are excluded from conversion.
You can add more as you wish.
I didn't have time to test it, so please test thoroughly.
Convert to CMYK (except named Spot Colors).eal.zip
(1.89 KiB) Downloaded 688 times
abc@imposition.com
stome
Post by stome »
This works perfectly! Thank you!
abailescollins
Excellent.
abc@imposition.com
stome
Post by stome »
Hello. Okay not totally perfect but close! I introduced a grayscale image (black channel only) into the mix but the action converts it to cmyk. Can there be something in this action to ignore grayscale images?
Best regards!
abailescollins
Give this one a whirl.
Convert to CMYK (except named Spot Colors + Grayscale Images).eal.zip
(2.02 KiB) Downloaded 653 times
abc@imposition.com
stome
Post by stome »
Thank you again! I'll be testing this action this weekend!
