Check PDF for multi-page or single
I'm building a switch flow that checks the incoming PDF to see if it's a multi-page PDF or a single page PDF. Depending on what is determined, each type will travel down their own workflow paths for individual processing. How do I examine the incoming PDF to see which type it is?
Re: Check PDF for multi-page or single
Make a folder with two connections. The first set "Include these jobs" to "Define condition with variables" "[Stats.NumberOfPage] Equal to '1' " and the other connection to "Define condition with variables" "[Stats.NumberOfPage] Greater than '1' " or make the second "All other jobs".
Between jobs!
