How to check for resolution
Is there an action list that will allow to check for resolution of all objects within a pdf?
Re: How to check for resolution
I don't know if you can do it with an action list, but a preflight profile can do it for sure.
The attached preflight profile will list the resolution of any image with a resolution below 1500 dpi.
Worst case just create a new Preflight profile, go to Images and select Resolution of. Set image type and resolution, then under General - Preflight report check the Images check box and you will get a preflight report when you run the preflight profile.
- Check resolution of images.ppp.zip
- (6.05 KiB) Downloaded 767 times
Hmm, how about the action "Check resolution"?
