Stuffit files
sgeller
Stuffit files
Post by sgeller »
Is there some trick getting switch to uncompress Stuffit files?
Been trying to work on a preflighting flow that works from zip or sitx files.
Unzipping works fine.
I bought the newest stuffit deluxe. But the configurator doesn't work with it.
Peter Kleinheider
Stuffit files
Post by Peter Kleinheider »
For this I use an execute configurator
Path to application: /Applications/StuffIt Expander.app/Contents/MacOS/StuffIt Expander
Arguments: "%1"
Destination: Result next to input file
peter
peter@inpetto.cc
inpetto:zipcon consulting
carineb
Stuffit files
Post by carineb »
It is also possible to do this using an Automator configurator in combination with an Automator workflow using Stuffit actions.
We will look into supporting Stuffit Deluxe 15 in future versions of Switch, in the mean time either Peters or the above can help you out.
Kind regards,
Carine
Enfocus Support Manager
