Pitstop check overlapping text
Erazor
Post by Erazor »
Hi all,
Does anyone know if it is possible in Pitstop Server, latest version, to check for overlapping text like you could for overlapping objects?
All input very welcome and thanks in advance!
Malcolm Mackenzie
Re: Pitstop check overlapping text
Post by Malcolm Mackenzie »
There's a prebuilt action
Find Overlapping Text
Erazor
Post by Erazor »
Hi Malcolm,
That is true but although it says it selects the text it actually checks for overlapping objects, not only text.
bens
Post by bens »
The Action List "Find Overlapping Text" logs any objects that overlap any text. That is indeed not what it says it should do, so I'd consider that a bug.
Luckily it's easy to fix: replace the "Select all" at the top with "Select text segments" (so you'd have two "Select text segments" in a row). Alternatively you could add "Duplicate top of selection stack" _after_ "Select text segments".
Jemis
Post by Jemis »
hi guys! I want to ask about overprint for stroke and overprint for fill, smash karts independent properties.
loicaigon
Post by loicaigon »
What is your question exactly?
