Covert Spot Color to CMYK Color
vrushalm
Post by vrushalm »
I have installed PitStop pro and from which i can able to convert spot colors to Process colors.
But i am looking for a solution to use from command line - CLI.
There is a PitStop server - CLI but, can it use that to convert spot color to process colors?
If yes, Then please help me how i can use ?
Please reply urgently. I have to implement this in minimal time.
loicaigon
Re: Covert Spot Color to CMYK Color
Post by loicaigon »
Rushing is generally not a good way for doing things great. But for what's worth, Using PitStop CLI requires usings xml configs files:
Here is the doc:
http://www.enfocus.com/manuals/UserGuid ... S/home.htm
And here is a sample:
http://www.enfocus.com/webmarketing/web ... rocess.xml
All you have left is edit the sample xml and use it in your CLI call.
vrushalm
Post by vrushalm »
Thanks loicaigon.
I used similar command as below and that worked fine for me. :)
"C:\Program Files (x86)\Enfocus\Enfocus PitStop Server 13\PitStopServerCLI.exe" -input "C:\Resources\input\input.pdf -mutator "C:\Resources\actionlists\actionlist.eal" -output "C:\Resources\output\output.pdf "
But I have one another question:-
Can PitStop server able to covert PS file to PDF ?
loicaigon
Post by loicaigon »
Glad you got it.
No PSRV can only process PDF files (unless I missed something).
vrushalm
Post by vrushalm »
Thank you so much loicaigon for clearing everything. :)
