Strange RGB color conversion behaviour
andreas_m
Post by andreas_m » Thu Jul 02, 2020 4:54 pm
Dear Forum,
i'm a little bit confused with my Color Mangement Settings.
As you see in 1. my rgb-profile is eciRGB v2.
In 2. you see that the selected picture has no profile embedded.
When i hit the color conversion butten (in 3.) PitStop suggests Adobe RGB (1998) as the profile where to convert from ...
Is that a bug or do i understand something really wrong? What am i missing?
Any help would be great ...
Thanx in advance
Andreas
Re: Strange RGB color conversion behaviour
Post by abailescollins » Thu Jul 02, 2020 8:28 pm
That is a bit strange, I would expect the settings presented to you in the window is the same as the color management preferences.
Can you report this one to Enfocus support please so they can investigate please.
Obviously you can change the Profile in the dropdown to the correct one, but that's not the point!
andrewb@enfocus.com
andreas_m
Post by andreas_m » Fri Jul 03, 2020 8:29 am
Thanks for your answer.
I'll contact Enfocus support and will post the solution. Just in case anybody else has this issue.
Andreas
Post by abailescollins » Fri Jul 03, 2020 11:14 am
Great thanks, I will follow the case as I am interested to see what's going on.
andrewb@enfocus.com
andreas_m
Post by andreas_m » Fri Jul 03, 2020 11:38 am
But the support seems to be for free only for 90 days after activating the license ...
andreas_m
Post by andreas_m » Tue Jul 07, 2020 10:39 am
It's a little bit strange but the preferences seem to work - but with two exceptions:
- Use settings from acrobat
- Color management switched off
I created a local preference with the same settings as "Use settings from acrobat" by hand and everything works fine.
Seems to be a bug (or a feature? ;-))
