Split Multiple Page PDF
apietrocini
Post by apietrocini »
Hello all,
I have a multiple page pdf that I need to split out dynamically. I know you can split by x amount of pages per file, but the problem I'm having is these are invoices and they can be any number of pages. Has anyone ever accomplished this.
Thanks,
Anthony
Malcolm Mackenzie
Re: Split Multiple Page PDF
Post by Malcolm Mackenzie »
Hi Anthony
If you could describe the logic for the split please.
If there are
5 pages you want out
10 pages you want out
18 pages you want out
etc
Thanks Malcolm
JimmyHartington
Post by JimmyHartington »
I have used this program:
http://www.a-pdf.com/content-splitter/index.htm
It can split files based on content and when it changes.
It can work manually, with hot folders and with the command line.
And it is only $79.
In my use case it has been manually for one time task.
But also incorporated it into flow with the command line.
In the program you make the rule for the splitting and can the use the rule file in the command line.
r.zegwaard
Post by r.zegwaard »
Why not use the "Split PDF" configurator of Switch?
JimmyHartington
r.zegwaard wrote: Mon Jul 08, 2019 7:48 am Why not use the "Split PDF" configurator of Switch?
Because in some cases you need to split a file, where it differs in the same file on which page count you want to split.
Like a pdf containing many invoices.
One invoice is 1 page, another 2 and maybe 3 pages.
But the first page always have a invoice-number.
So with some of the programs you can define it to look for text a certain place and split on this.
So you end up with a pdf for each invoice with variable page count.
laurentd
Post by laurentd »
The Split PDF pages app written by Freddy solves this.
There are 8 different strategies for splitting, including
  • a change of page size
  • a change of color (from gray to color or vice versa)
  • the presence of one or more empty pages
  • the presence of a bookmark
  • cover and body content for books
  • a PitStop Action List to detect elements such as chapter heads
Freddy explained it in a monthly workshop in September 2021.
