Add appendix pdf after every page of letter pdf
JimmyHartington
Post by JimmyHartington »
I have a flow, where I need to insert an appendix pdf after every page of a letter pdf.
The number of pages in the appendix pdf is not the same for each run.
The number of recipients in the letter pdf is also variable.
My solution now is to split the letter pdf. Using the command line tool PDFTK I insert the appendix pdf. The job is then assembled and merge to a new pdf-file.
This works but can be very slow, if there are many recipients.
So I was curious if any one had a good tool for this?
JimmyHartington
Re: Add appendix pdf after every page of letter pdf
So I found a solution based on a Acrobat javascript.
Now I use the Acrobat configurator.
This is the script.
/* Add blank page for script to work */
$doc.newPage(0, 100, 100);
/* add page after each nth page */
var n = 1;
for (var i=$doc.numPages-1; i>0; i--) {
    if ((i+1) % n == 0) {
        $doc.insertPages(i, "/path/to/appendix/pdf-file/" + $arg1);
/* Delete first page */
$doc.deletePages({nStart: 0, nEnd: 0});
Arguement 1 is the name of the appendix-file.
It is faster than my previous solution, but still not as fast as I would like.
What I would like was some kind of commandline utility.
3f8h.net
Post by 3f8h.net »
We can do this using callas pdfToolbox CLI.
Sebastian Nafroth
3f8h.net / electronic publishing
Orchestrating publishing workflows since 1999
Oswald-Haug-Weg 3 / D-79312 Emmendingen
Tel +49 7641 967 36 9-0 / Fax +49 7641 967 36 9-9
sna@3f8h.net / https://3f8h.net
JimmyHartington
How is it done with pdfToolbox CLI?
Arthur
Post by Arthur »
Quite Imposing - insert pages ('from file' at interval).
Done.
JimmyHartington
@Arthur
Thanks. But I do not have Quite Imposing for my server.
It needs to be done automatic.
Arthur
Post by Arthur »
Well - it can be automated with Quite Hot Folders. But I presume you do not have that one either....
We've been using Quite for years and it was a natural choice to keep things that way when we implemented Switch. But I understand not everyone has got it, in favour of other tools.
Yet - this seemed the most straightforward solution to me....
3f8h.net
Post by 3f8h.net »
Do you have pdfToolbox CLI installed and licensed?
Sebastian Nafroth
JimmyHartington
@3f8h.net: No. I do not have a license for pdfToolbox CLI.
