I haven't found a way to do this yet: I have documents using a custom spot color, and need to update it based on whether another custom spot color is found.
Basically, if Custom Spot Color 1 is found, search for Custom Spot Color 2 and change to Custom Spot Color 3.
If Custom Spot Color 1 is NOT found, search for Custom Spot Color 2 and change to Custom Spot Color 4.
Any thoughts?
conditional Spot Color search/replace
Re: conditional Spot Color search/replace
Is this just in PitStop, or is it within Switch?
abc@imposition.com
abc@imposition.com
Hello! I am working in PitStop Pro 2018.
Ok, are you registered for the PitStop Monthly online workshops?
I'll cover this as a use case next Wednesday.
https://www.enfocus.com/en/events/month ... -workshops
abc@imposition.com
abc@imposition.com
I am now (registered for the workshops)! - thank you so much.
Cool, it'll be fun!!
abc@imposition.com
abc@imposition.com
Hope you saw it, did it all make sense?
abc@imposition.com
abc@imposition.com
Works for me! Far simpler than I had imagined - thank you for investigating/sharing.
Select spot color (specify)
Select page if content is selected
Remap spot color
NOT
Remap spot color
I'm keeping that template for other conditional edits the future may hold . . .
Remap spot color
NOT
Remap spot color
