Problem with backslash character \
Krzysztof Mycek
Post by Krzysztof Mycek »
I have a question because I can’t find any information about my problem.
I need to separare part od path included in the XML file and metadata, witch is like for example: 0450-06-2021\karton.pdf. I need only part before \ character 0450-06-2021. Unfortunately when I use funcion Before \, this character is not recognized.
Do You have some idea how I can get only part before backslash?
My XML file is like:
<Positions>
<Position>
<position_id>124519</position_id>
<order_id>25069</order_id>
<client_name/>
<width unit="cm">100.00</width>
<height unit="cm">100.00</height>
<surface_name>BACKLIT FLASH; 1800X2400;</surface_name>
<color_name>brak</color_name>
<printer_machine_name>FABRI</printer_machine_name>
<file_path root_path="\192.168.1.193\DTP2">0450-06-2021\karton.pdf</file_path>
</Position>
</Positions>
Zrzut ekranu 2021-08-2 o 16.17.25.png (93.11 KiB) Viewed 12427 times
jan_suhr
Re: Problem with backslash character \
Post by jan_suhr »
Have you tried to escape it, \\
Jan Suhr
Color Consult AB
Sweden
Check out my apps
Krzysztof Mycek
Hi Jan
Unfortunately not working too. I try to use many combination.
Zrzut ekranu 2021-08-2 o 16.31.29.png (93.54 KiB) Viewed 12424 times
jan_suhr
Post by jan_suhr »
Then try \/
Switch can for paths "normalize" slashes to be working on both platforms.
Jan Suhr
Color Consult AB
Sweden
Check out my apps
Krzysztof Mycek
Any combination not working.
\/ no
\\ no
// no
"\\" no
ect ect
jan_suhr
Post by jan_suhr »
In the search field you can use Regular expressions to pickup parts from your variable value. That way would probably solve the problem.
Jan Suhr
Color Consult AB
Sweden
Check out my apps
Krzysztof Mycek
Maybe that is the solutions but a little complicated.
Thank You Jan. Maybe someone else will have an idea and face such a problem
Krzysztof Mycek
That is the solution: ^(\d{4}[- ]\d{2}[- ]\d{4})|()$
Of course only for this case.
laurentd
Post by laurentd »
Another solution: use the StringSplitter app with separator \
The result will be in private data Split.Part1
https://www.enfocus.com/en/appstore/pro ... ngsplitter
