Compact ICC-profiles?
magnussandstrom
Post by magnussandstrom »
Hi, for the last couple of weeks we have received print files with images with embedded icc-profiles that our DFE have issues to render properly.
One profile is named uRGB and one is called sRGB imageoptim.com. After some investigation they both seems to be something called Compact ICC Profiles. https://github.com/saucecontrol/Compact-ICC-Profiles
It would be great if there was a way to detect these profiles with Pitstop since they are causing issues for us. Any suggestions?
Example files: https://bit.ly/3tOGICx
PPNINJA
Re: Compact ICC-profiles?
Post by PPNINJA »
Umm what profile/do you run with Mag? :?:
You could set up preflight check to reject or report on non compliant icc profiles that your DFE does not use.
bens
Post by bens »
If you have the problematic ICC profiles you could use "Select by tagged ICC profile", browse to the profile (it will be embedded in the Action List), and use "Log selection" to generate an error, or a colour conversion to convert it to a good profile.
