I might be going crazy but I can't figure this out...
I have a folder structure that is 4 folders deep, that files are submitted into and I need to route and archive them accordingly. In creating this simple flow, I originally had the system working where the variable Job.Hierarchy was providing the full path/hierarchy, which is what I want to achieve, but for some reason it is now only providing the last level of subfolder in the hierarchy path. For instance I want the Job.Hierarchy to provide, "1;2;3;4", and currently, if I submit a file into a level 4 folder, I am only getting, "4".
Thanks for the help.
Not sure what I'm missing.
Attach Hierarchy Info
GSBSwitch1
- Screen Shot 2022-08-02 at 4.14.28 PM.png (8.98 KiB) Viewed 5705 times
GSBSwitch1
Re: Attach Hierarchy Info
This is the folder structure I am submitting files into and the results I am getting.
I need to extract the full hierarchy/path such as: "INDIGO DFE HOT FOLDERS;B2;B2IMPO1o0"
Could it be, that your Archive Hierarchy subfolder level is still set to the default of 1?
