problem with doubble sided image with tunnel
Robbie
Post by Robbie »
I need to print a double sided banner (front and back is the same image) on the top and bottom there needs to be a tunnel. On page 1 the top and bottom of the image needs to be copied and flipped (so when you create the tunnel the image on the back aligns with the image on the tunnel.
On pag 2 the image just needs te be centered and where the tunnel is going there is no image (white).
But the page size off page 2 is not correct. mayby somebody can help me with this i cannot seem to find where the error accourse.
Using pitstop 2022
Schermafbeelding 2022-11-02 om 12.48.16.png (99.25 KiB) Viewed 4611 times
Schermafbeelding 2022-11-02 om 12.48.25.png (70.24 KiB) Viewed 4611 times
Tim Murphy
Re: problem with doubble sided image with tunnel
Post by Tim Murphy »
We have played with this also, but being fairly new to Pitstop, we get lost in the jargon.
This would be an amazing action to get.
Not to mention when side 2 is a different image!!
Fingers crossed.
Robbie
Post by Robbie »
Its a nice action flow if it works. we also have a action flow for different images (front and back). but somewhere in the latest version of pitstop there are things not working anymore. such as this flow and the options for extra bleed, in the old version that we have its working but in the new not.
david.ayha
Post by david.ayha »
I'm not sure if Im understand you, can you show PDF files original and fixed.
You uploades your action but you need uplad also your variable set.
Visit my Youtube Channel https://tinyurl.com/prepress-world
