node.js debugger setup
noahberkley
Post by noahberkley »
Is there a video or guide on how to set up visual studio code debugging with Switch scripts?
foxpalace
Re: node.js debugger setup
Post by foxpalace »
Thanks for the video!
There is one thing extra that should be mentioned: this very easy method (it is all pre-configured) is available when you work with script folders. You can use the SwitchScriptTool for that, or you can right click on a "Script element" and create the script folder from there. Extra remark: the use of TypeScript is heavily recommended.
noahberkley
Thank you both!
