[Solved] Combine several XML
FlorianDSK
Post by FlorianDSK »
Is there a way to collect multiple XML's (10+), take all the information out of them and write it into one XML?
Many greetings
Florian
jan_suhr
Re: Combine several XML
Post by jan_suhr »
The app Make XML can do it.
Jan Suhr
Color Consult AB
Sweden
Check out my apps
FlorianDSK
Hello Jan,
Thank you for your quick reply.
But is there no other option than another payment app?
kindly
Florian
magnussandstrom
Post by magnussandstrom »
If you install Saxon (open source software) and use the Saxonica configurator in Switch you should be able to merge XML files.
Install: https://github.com/Saxonica/Saxon-Archi ... n-HE/9/9.9
About the merge instruction: https://www.saxonica.com/html/documenta ... merge.html
Strangely I can't seem to download the 9.9 HE version from Github anymore.. maybe someone can help out here?
FlorianDSK
Hello Magnus,
Thank you for your answer. Appreciate that
But I have now solved this using a batch file :D
Thanks anyway
Kindly
Florian
joaodaffonsojr
Re: [Solved] Combine several XML
Post by joaodaffonsojr »
Hi !
I have two XML like 32800_ARQOS.xml and 32800_ODTPLIMP.xml that i need to merge.
I tried with SAXON in the cmd line, I did a XSLT and works.
But how can I use the variables of Switch like [Job.Path] and [Job.NameProper] to make SAxon configurator merge them ?
Any tips are very welcome !
