Remove Printer Marks
Moderators: anncoupe, anncoupe
Mongoose
Post by Mongoose »
Hi
I want to introduce this action to a Switch workflow to remove all printer marks from all pdfs
My problem is I am apprehensive in doing this to every job as I remember a user reporting that it had removed part of an image on a job
Perhaps with recent updates it now works without any issues
We are running Switch 2022 Fall and would just like some views before implementing
Cheers
loicaigon
Re: Remove Printer Marks
Post by loicaigon »
You may probably reference this post: viewtopic.php?p=15053&hilit=marks#p15053
But that was fixed with the user. If you want to put your mind at rest, you can simply test it in Acrobat with PitStop Pro first. If you were still in trouble at that time, you can get in touch at loica (at) enfocus (dot) com.
Yeagaing
Post by Yeagaing »
loicaigon wrote: Fri Aug 18, 2023 5:34 pm Hi,
You may probably reference this post: viewtopic.php?p=15053&hilit=marks#p15053 fnaf games
Oh thanks for the relevant link.
