Activation "AWS S3 Download"
schmitzdp
Post by schmitzdp »
I'm trying to enable "AWS S3 Download" on Switch. I also installed and configured "AWS CLI".
However, I get this error message:
Is there anything I forgot?
(I have already restarted my PC under windows.)
Thank you.
mkayyyy
Re: Activation "AWS S3 Download"
Post by mkayyyy »
I ran into the same issue with the AWS S3 Download app
The only way I ended up getting it to work was by using the script version from here: https://github.com/open-automation/switch-aws
schmitzdp
Post by schmitzdp »
mkayyyy wrote: Wed Dec 16, 2020 7:08 pm I ran into the same issue with the AWS S3 Download app
Even with this script, I have the same error result.
However, here is what I get in the command prompt
C:\>aws --version
aws-cli/2.1.11 Python/3.7.9 Windows/10 exe/AMD64 prompt/off
Does anyone have an idea? Thank you
schmitzdp
Post by schmitzdp »
Up :?: :idea:
schmitzdp
Post by schmitzdp »
Finally, I used the suggested version of the script. Then I modified this script because the "AWS CLI" check was actually blocking the download.
mkayyyy
Post by mkayyyy »
Apologies for the delayed reply, glad you were able to sort it in the end!
Farva
Post by Farva »
I am currently having this issue as well. Could you share the updated script or does anyone else have a solution?
MY001
Post by MY001 »
Anybody found a solution for this?
@schmitzdp could you please share what adjustment you did on the code to make this work?
schmitzdp
Post by schmitzdp »
in the script, I deactivated what was related to AWS CLI, if I remember correctly
https://www.schmitz.be/S3%20Download.sscript
taylorgodiva
Post by taylorgodiva »
Those are errors that I often encounter, I'm glad you found the answer
Geometry Dash Scratch
