Is it possible in Switch without the scripting module to automatically save all flows and their contents at a certain time as a backup in a folder in order to reload them in the event of a failure at time X?
thanks und regards
Switch Backup without Scripting
Re: Switch Backup without Scripting
I think you will find what you are looking for in the answer from cedric.sintes in this thred:
viewtopic.php?p=11012#p11012
weavesingle
There is an option called "Save flows automatically" that saves flows before activating them; perhaps that is sufficient for you?
- tdeschampsBluewest
The solution of Cedric sintes is also in an APP "autosave plus", sadly in legacy, so it may disappear in a near future, or have some compatibility problem when the support for legacy will end.
I may redevelopp it in typescript for the appstore, and i think we may put it for free, but it's a matter of time and priority (a lot of other app under developpement
Keep in mind that both solution (Cedric one, and on the appstore) do not behave like a right click/export => It won't have any propertyset in it, you need to save them alongside your flows.
hoopigoldber
Switch does not have a built-in option for automatically saving all flows and their contents at a predetermined time without using the scripting module. This feature necessitates the capacity to interact with the Switch environment programmatically, which is essentially the responsibility of scripting.FlorianDSK wrote: ↑Wed Nov 22, 2023 9:37 am Hello,
thanks und regards
