Hi all
This is my first post.
Is it possible to add a box offset by 4mm around a selection of 6mm dots.
I can select the dots no problem by size, and change colour of them or group them if I need to.
These dots are registration dots for the kongsburgh so they are positioned around the printed items on the media.
Select 6mm Dots and add key line
- JimmyHartington
Re: Select 6mm Dots and add key line
If you can select the dots, I would set the art box to the bounds of the selection.
Extend the artbox +4 mm on each side.
Add a rectangle based on the art box.
Optionally delete the art box afterwards.
I will give that a go and let you know.
That works a treat.
Thanks Jimmy
Not sure how to attach the action for others members to use/see
Thanks Jimmy
When you reply to a message you will see two tabs below the editing box: Options and Attachments. Once you have added the file you can place it inline. Thanks for sharing!
