Reduce bleed
MJDS
Reduce bleed
Post by MJDS »
Is there an easy and safe way of reducing bleed on a page. For example the file has been supplied with 25 mm of bleed and needs to be reduced to 5mm
loicaigon
Re: Reduce bleed
Post by loicaigon »
You can use this action:
In short:
  • Extend trim temporarly to have bleedbox dimensions
  • Clip bleed around contour using trim as contour/list]
    • Contract trim to its initial size
    Hope that helps
MJDS
Re: Reduce bleed
Post by MJDS »
Cool
Just tried it, works well
