Quite hot imposing
babathemacman
Quite hot imposing
there is someone who is familiar with quite hot imposing, I want to place an A3 lying 2x but I can not. I made an example pdf for the 750x530 format but he does not place it. Original disappears and in case of error I only see "error". does anyone know how to do this?
Re: Quite hot imposing
If you write to them, they will make anything you need.
Are you using Quite Hot in Switch?
iTAMAR MARIANO
Segue o exemplo criado no Quite Hot Imposing
- 1- Passo.png (84.39 KiB) Viewed 22276 times
- 2- Passo.png (84.07 KiB) Viewed 22276 times
- 3 - Passo final.png (34.59 KiB) Viewed 22276 times
